PT wood fascia - just learned aluminum will not mix!!!
Old 03-08-19, 02:14 PM
MrPC1's Avatar
Received 1 Vote on 1 Post
So i put up a new fascia out of PT wood. Seemed like a good idea, but i learned today that it is no good when mixed with aluminum. Needless to say, I have to take it down and replace with some new wood. What type should I use? Regular pine? Will it need to be painted even though it will be covered in flashing? I just put it up not too long ago and right now I have no problems as of yet but I want to get it taken care of asap! SMDH. Thanks
Old 03-08-19, 02:19 PM
Received 359 Votes on 316 Posts
Regular untreated unpainted wood should be fine. While a coat of paint doesn't hurt, hardly anyone does.
Old 03-08-19, 02:40 PM
MrPC1's Avatar
OK thanks. I'm upset I have take down my gutter and do this once again. But I am also happy that I caught it early before I replaced all of my fascia, or it ate my brand new aluminum gutter. lol
Old 03-08-19, 02:44 PM
P
Received 744 Votes on 684 Posts
I would not re-do what you already have up. Just let it go. You can deal with any issues if they every appear.
Old 03-08-19, 02:47 PM
MrPC1's Avatar
Im really worried about it eating my gutter and the drip edge soon to go up. I already have to pull the gutter down because I do not have the correct flashing behind it. I might as well just do it now.
Old 03-09-19, 05:47 AM
P
Yea, if you've gotta take the gutter down anyhow you might as well do it right. If you want to leave the pressure treated up there I would put a strip of tar paper between it and the aluminum.
The reason you can't put aluminum over modern pressure treated lumber is because of all the copper used in the treatment. It can create galvanic corrosion with any dissimilar (not copper) metal. All you have to do is prevent them from touching each other. Note that this corrosion will also attack your nails and screws so make sure you are using fasteners approved for treated lumber. They have extra coating layers to protect them from the corrosive environment.
Old 03-09-19, 08:01 AM
XSleeper's Avatar
Received 774 Votes on 715 Posts
That's another reason why PT wood is not good for fascia... are your gutter fasteners ACQ approved? Doubt it.
Old 03-09-19, 08:18 AM
MrPC1's Avatar
I used deck screws to hang the fascia, but gutter fasteners? Highly doubt it. Smdh. The tar paper is tempting, but I know how my luck has been so I don't want to take a short cut.
Old 03-09-19, 08:30 AM
MrPC1's Avatar
What type of wood should I use? Is pine too soft?
Old 03-09-19, 08:38 AM
MrPC1's Avatar
Or..............Could I just use PVC board and negate the extra cost by not having to buy or use flashing? And again, I truly appreciate your advice. I do not know where I would be without it.
ANOTHER FUN FACT: I also just learned what a sub fascia is. There was none on my home. It was just a 1" piece of lumber attached to the rafters, and that is how I replaced it. I know the most proper way to do it would be to add a sub fascia, but the original soffit wasn't built to accommodate this. Should I just leave it alone and forget about a sub fascia? I know my home isn't the only one without one.
Old 03-09-19, 09:01 AM
XSleeper's Avatar
Use pine. If it is getting covered it should never get wet. PVC will cost 2x what wood and aluminum fascia cover cost.
Old 03-09-19, 12:31 PM
MrPC1's Avatar
Thanks. Just got some cheap pine from a lumber supply today! As far as the flashing goes, Can i just use a roll of something like this (below), or should I go with something pre bent?
https://www.homedepot.com/p/Amerimax...8010/100064203
Old 03-09-19, 12:32 PM
XSleeper's Avatar
Unless you have a metal brake, I would use prebent fascia cover. It comes in 4, 6, 8".
Use gutter apron over the back of the gutter.
Old 03-09-19, 12:42 PM
MrPC1's Avatar
Ahhhh. I do not have a brake and am not into learning how to bend it myself. Hmmmm. since the flashing that came with the original fascia only comes up half way form the bottom (i don't know why either)- maybe I could leave that up and go over it with a 6 inch roll of aluminum? Thoughts? I'm trying to save money where i can.
Old 03-09-19, 12:48 PM
XSleeper's Avatar
Get prebent fascia cover that will be wide enough. You want the fascia to be long enough that it extends all the way under the gutters so that it is above the top of the gutter.
Old 03-09-19, 12:52 PM
MrPC1's Avatar
Sweet. I'm happy I can just add to what I already have rather than buy 56ft worth of pre bent fascia flashing.
Old 03-16-19, 07:28 AM
MrPC1's Avatar
So I have the pre bent fascia up. I had to cut a piece to fill a small gap at the end. The seam overlaps a couple of inches but does not lay very flush. Should this be caulked underneath, or let it go? In theory when the roofers put on the new roof and drip edge it shouldn't get wet. Thanks.
Old 03-16-19, 10:14 AM
XSleeper's Avatar
Trufthfully, no professional would use a piece that small for the reason you have just discovered... they just look bad. You measure things before you start to plan the lengths of your pieces and where joints will be. So do whatever you think. If you would have bent the piece inward a little so that it would lay tighter, it would have looked better. I would take that little piece off and put on a longer one, even if it meant it would overlap 2 feet.
Old 03-16-19, 10:37 AM
MrPC1's Avatar
Yeah, I measured wrong and was off by like an inch. I should have a longer piece leftover when I am done this job. I will just use that and let it overlap. Thanks.
