How much water can a basement window well handle ??
Old 03-18-19, 03:45 PM
W
Received 1 Vote on 1 Post
My basement window does not have a drain . Im curious how much water can a window withstand before it comes inside.
Old 03-18-19, 03:58 PM
XSleeper's Avatar
Received 1,528 Votes on 1,372 Posts
Most basement window wells don't have drains... so it depends how many inches it is from the bottom of the window opening to the gravel below. Also depends on if water from the lawn can drain into it or if it's simply what falls from above. Most people will put a cover over them to keep rain out.
Old 03-18-19, 04:20 PM
W
I had a leak into the inside . Was a warm day /thaw and a decent amount of rain fall.
[IMG]http://i64.************/257hy07.jpg
Old 03-18-19, 04:26 PM
Received 2,954 Votes on 2,665 Posts
That is hosted on a site the DIY board doesn't allow. What is that site.... I can grab it and post it.
Old 03-18-19, 04:30 PM
W
It's from tinypic..........
Old 03-18-19, 06:46 PM
W
I edited my post it appears now
Old 03-18-19, 07:04 PM
XSleeper's Avatar
Well yeah, that gulley that is funneling water from the lawn down there might be the problem.
Old 03-18-19, 07:13 PM
W
What is meant by gulley, the hole in front of the metal??
Old 03-18-19, 07:19 PM
XSleeper's Avatar
gul·ly
/ˈɡəlē/
noun: gulley
1. a water-worn ravine.
synonyms: ravine, canyon, gorge, pass, defile, couloir, deep narrow valley;
verb: gulley
1. erode gullies into (land) by water action.
"he began to pick his way over the gullied landscape"
Old 03-18-19, 07:22 PM
W
That u meant the hole in front of the metal that all the water created.. so I guess I need a french drain??
Old 03-18-19, 07:27 PM
XSleeper's Avatar
You just need to quit funneling all the water from your lawn and roof down the window well. The grading around the house is atrocious.
Old 03-18-19, 07:31 PM
W
It's the window on the left/closest in the pic that's leaking . The roof water is all going to the front of the house . Downspout is going along the side of the house towards the front
Old 03-18-19, 07:36 PM
XSleeper's Avatar
Yeah its obvious which window it is by the path of mud and water leading to it.
Old 03-18-19, 07:59 PM
W
So fill that gulley with dirt and the hole . Will make it slightly better ? Before getting into heavy duty land grating ?
Old 03-18-19, 08:02 PM
XSleeper's Avatar
That and the entire foundation perimeter. The landscaping looks lower than the grass!
Old 03-18-19, 08:22 PM
W
How about in this pic does the grading still look bad ??
So how should I fix this . How much dirt and how far from house.
Old 03-18-19, 08:28 PM
XSleeper's Avatar
If you are buying the soil from the big box, I imagine you could lay at least 2 bags end to end all the way around the house if you wanted and it wouldn't hurt. A little math and you would know how many to get. Or contact a landscaper for an estimate.
Old 03-18-19, 08:39 PM
Your pics are on pichost(dot)org now. DIY blocks hosting from tinypics.
Old 03-18-19, 09:30 PM
W
How far away and high from foundation should I come out
Old 03-19-19, 06:04 AM
A
Received 214 Votes on 197 Posts
There should not be a depression all around the house filled with gravel or mulch. Fill it all in (excluding the interior of the window well) using dense clay soil (not sand) so that water will run away from the house.
  #21
Old 03-19-19, 08:29 AM
Marq1's Avatar
Received 946 Votes on 859 Posts
It's difficult to estimate material, but water flows down, your beds, the gully, the gutters, the entire yard should be higher and directed away from the well to keep water out!
  #22
Old 03-19-19, 05:36 PM
W
It's a rental property. So I am trying to do the cheapest way possible.
option 1 put soil all around foundation extruding 2 to 3 ft out ??? And then resod??
Option 2 . I re level entire property which costs alot and I have to re sod and I doubt tenants would do it for me .
3.I had some landscapers saying to put a rock maintenance strip drain/ weeping tile about a foot and a half deep around foundation covered with gravel, terminating to front of house ..?
4. Adding french drain to window..
  #23
Old 03-20-19, 11:53 AM
A
No!
This will harbor water against the house and encourage leaking through any cracks in the foundation.
  #24
Old 03-20-19, 04:41 PM
Norm201's Avatar
Received 594 Votes on 531 Posts
You say its is a rental. Why isn't the landlord addressing the problem? It's his investment, not yours. Or are you considering buy it?
  #25
Old 03-22-19, 09:27 AM
W
its my rental property/I AM the landlord/ owner. I guess everyone needs specifics now adays!!!! I am trying to keep costs down!
If I was a renter would I be wasting my time asking questions.
I am stumped which route to take,. window well drain or regrade the land
  #26
Old 03-22-19, 09:37 AM
Norm201's Avatar
Regrade the land. That is more important and will do more good than any drainage. You might need drainage later on, but reducing or eliminating the source of the water is more important. Plus, regarding will add better aesthetics to the property.
  #27
Old 03-22-19, 09:44 AM
W
Concern I have is . Who will water the sod /grass after doubt tenants will do it . Also how will I get the water to funnel between the houses ??
  #28
Old 03-22-19, 10:05 AM
Norm201's Avatar
You don't necessarily need grass. A ground cover plant will do the job and absorb lots of water. GOOGLE "moisture absorbing and fast growing ground cover plants" for a list of plants. As far as who will water it to start with? Well that is something that you will need to resolve. Hire some kid or pay the tenants to care for it. Maybe a slight reduction in rent for the first month or two?
I have a similar situation between me and my neighbor. I graded that side of the house so that a slight trough or depression is made from the house to the middle part of the ground between our homes. Except in a torrential down pour, I eliminated basement water leak by grading.
  #29
Old 03-22-19, 01:29 PM
W
Sounds helpful but what about winter months/thaw In spring
  #30
Old 03-22-19, 02:42 PM
Norm201's Avatar
Again with proper grading and using the proper soil/clay mixture, and an established ground cover be it grass or other, it should not be a problem.
  #31
Old 03-22-19, 03:01 PM
W
Ok how far from house foundations should I come out with grading 3 or 4 feet ??
  #32
Old 03-22-19, 03:14 PM
XSleeper's Avatar
2 maybe 3 feet at the most. Like I said, imagine a bag of soil laying on the ground. That's about the size/area/volume you need to raise. This isn't rocket science.
  #33
Old 03-22-19, 03:51 PM
W
Perfect so I ll count the same amount for the side of the house that's beside the neighbor and do the same !! Just need to find soil that is more clay style.
is there any plants that absorb water in the winter months??
  #34
Old 04-02-19, 03:17 PM
W
Do I put the dirt right on top of the grass? And or resod /seed after ???
