DIY Gutter Vacuum Cleaning
Old 01-23-23, 10:23 PM
Received 3 Upvotes on 2 Posts
I ended up making a gutter vacuum to vacuum out my gutters from the ground. It worked out very well. I used two 8' sections of Nutone 2" piping and it is easy to maneuver. I vacuumed my gutters after the last leaves fell and I've had several months of rain and no clogged gutters. The parts are cheap and easy to put together.
Old 01-23-23, 10:51 PM
Marq1's Avatar
Received 1,137 Upvotes on 1,031 Posts
Now put in some Gutter Stuff and you'll ever have to do that again!
WML13 voted this post useful.
Old 02-04-23, 09:17 AM
W
Received 40 Upvotes on 36 Posts
If you ,or anyone for that matter, invests the money and time now, to put in a gutter cover system, as you get older you will notice your neighbors up on the ladders and playing with vacuums and blowers in the fall, and feeling GREAT because you don't HAVE to (clean gutters). even if you are still ABLE to. 10-4 to Marq1! (ten years and 5 properties, and my thousands of leaves all get safely on the ground for me to vacuum with a 20HP Simplicity tractor and blower vac system
Old 02-14-23, 04:19 PM
N
Received 5 Upvotes on 5 Posts
Hey check my posts about gutters. My gutter system is the best and cheapest imo. Everything you need is from your local orange store. Good luck.
