2nd Floor subfloor for carpet?
I live in an expanded cape and I have 2 bedrooms and a full bathroom upstairs which my family doesn't use yet but we will be moving the little one upstairs before baby #2 comes.
I moved into the home about 4 years ago and always noticed how loud it was when somebody was walking upstairs so I decided to take a look at the subfloor. It looks like very thin MDF (possibly) subfloor that is underneath the carpet. It's definitely not even plywood or OSB. I can't even see this being legal and since I am in the process of remodeling the upstairs And changing the carpet figured I would rip that subfloor out and put a proper subfloor before the new carpet and trim goes in.
Is it ok to use 3/4 OSB for a subfloor where carpet will be installed or should I get 3/4 plywood?
You generally want to use 3/4" tongue and groove for subfloors, glued and screwed. It gets layed perpendicular to the joists. Either plywood or osb are commonly used. Plywood is higher quality and a little more expensive.
While either will work, I would feel better with plywood, personally. I can't stand the thought of shampooing the carpet from time to time and soaking the osb.
Have had both, plywood and OSB, over the years without any concern, tongue and groove for sure!
I believe that particle board (not sure if same as MDF) was used along with plywood many years ago as a way to make quite floors.
I do not recall if one was on top or below the other.
You may be able to determine if it can be covered!
Thanks! I will have to rip up just a section of the subfloor to see if plywood is beneath the MDF/particle board.
And by "cover" you mean to lay the new plywood directly on top?
