Best Carpeting for Basement
Old 07-12-23, 07:37 PM
Hello,
Iíve been shopping for carpeting for my basement. After visiting several stores I liked a wool blend (80% wool and 20% poly silk). However Iíve read some articles that wool is not a great choice for basements because it absorbs moisture.
My basement doesnít flood, but it does get humid. I run a dehumidifier at all times during warm weather.
Would you suggest that I choose a different fiber? My second choice was a nylon.
Thank you in advance.
Old 07-12-23, 11:52 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
The carpet really doesn't matter but hey make special pads that are used in basements, you want to look into that!
Old 07-13-23, 06:42 AM
sam floor's Avatar
Received 38 Upvotes on 32 Posts
I would go with a nylon or polyester. As you said, moisture it tough on wool.
Old 07-13-23, 07:28 AM
Received 297 Upvotes on 267 Posts
If the moisture is coming up through the floor then I would not be putting carpeting on it.
Old 07-13-23, 09:18 AM
Norm201's Avatar
Received 729 Upvotes on 644 Posts
My suggestion is indoor/outdoor carpeting.
Old 07-14-23, 10:35 AM
sam floor's Avatar
There is always Kangaback carpet, it resists moisture and is easy to DIY.
