Attaching Armstrong track to concrete
Old 07-04-16, 07:16 PM
I am using Armstrong T molding to transition between two laminates at a doorway. It has a metal track that attaches to the floor and the T molding snaps into the track. I used this upstairs, but I could screw the track to the subfloor. The now project is on concrete. Do I just use adhesive like Liquid nails to attach the track to the concrete? If not, how do you attach it?
Old 07-04-16, 07:19 PM
Received 3,415 Upvotes on 3,063 Posts
Not knowing exactly what the track looks like.... I'd think you'd use plastic or small lead anchors and screws into the concrete.
A 1/4" anchor would work good.
Old 07-04-16, 08:26 PM
ray2047's Avatar
I've never used it but they do make tack strip adhesive. Example: https://www.amazon.com/MasterWeld-Ta.../dp/B003BS4D0Q
