Help identifying type of wood used in hardwood flooring
I need help identifying the 2 different types of solid hardwood flooring in the 3 pictures below. The first photo is from the dining/living room of our first floor circa 1923 home. The other 2 photos are from the kitchen. There was tar paper scraped off the top of the kitchen flooring. Some residue remains which makes it difficult to see the wood in the photos. The wood in the kitchen has less dark grain pattern and is more uniform in color and pattern than the dining/living room.
The first photo looks like oak but I can't really see the wood in the other two photos. Usually the same type wood is used throughout the house if you think it was all installed at the same time. If you think a room was remodeled you'll have to do some investigating. Sanding the dirty floors so the wood and it's grain are visible will make identifying the wood much easier.
The two rooms are separated by single perpendicular strip of wood. I'm not sure what type of wood they are but I am positive they are two different types of wood. Maybe they wanted a more showy type of wood in the kitchen and something cheaper in the rest of the first floor, I'm not sure but I'm believe they were installed at the same time and are different types of wood.
There were some walls, chimney removed where the flooring needs to be patched in before it is sanded. Sanding it at this point for identification purposes would cause more work and hassle.
It might be a hassle but you need to know what type of wood it is before you lace in new. The 2nd pic could be maple but it's next to impossible to say for sure with no more than we can see.
Another thing is the size of the boards - they have changed some over the years. Is there a closet or some other out of the way place you could 'steal' boards to replace with?
The first picture is white oak, it will be easy to match because of natural wood variations in color.
I would sand the first cut before making any repairs. That's the only way to choose your replacement planks based on natural color.
First picture looks like face sawn cheap pine or spruce to me.
I have a rental that looks exactly like it.
