Plywood Plank Flooring over existing Hardwood
Old 01-02-17, 11:08 AM
Smile Plywood Plank Flooring over existing Hardwood
Because of time and cost the position I'm looking into is to lay a plywood plank floor (such as you see in a lot of DIY forums) over an existing hardwood floor. If ripping up the old hardwood isn't an option how would you go about laying the new planks over top?
I'm also limited to the new floor being no thicker than 3/4" over the old floor.
An example of what we're trying to achieve.
Remodelando la Casa: DIY - Plywood Floors
Thanks in advance for any support.
Mike
Old 01-02-17, 12:51 PM
Received 98 Votes on 86 Posts
Welcome to the forums.
I'd only heard of this flooring one previous time. Does it have a wear-resistant finish applied? My biggest concern with plywood is that you would wear through it in short order.
Old 01-02-17, 01:19 PM
Marq1's Avatar
Received 460 Votes on 429 Posts
My first question is why cover the existing floor, could it be refinished!
I just dont see a plywood floor being something that would last a long time or be all that appealing!
Old 01-02-17, 01:36 PM
@stickshift ... I saw this for the first time a year ago and couldn't be convinced it wasn't actual hardwood. Since then I've met a contractor who has done it a few times and says it's a legitimate option. But he's never done it over the old floor. The plywood is finished with polyurethane and so has that durable top coat on it. There are several examples of this method being used in retail locations, and homes with children and dogs and the owners swear it's holding up after several years.
@Marq1 ... the existing floors are going to be useless after a few walls and a kitchen are removed so either way I need an alternative.
Old 01-02-17, 02:30 PM
I believe the durability when I see it; poly on plywood does not sound durable enough for foot traffic to me.
Old 01-02-17, 06:14 PM
sam floor's Avatar
Received 17 Votes on 13 Posts
I can't see the plywood lasting very long even with poly. What about the voids? A lot of plywood has voids in the layers.
