Stained floors
Old 01-14-17, 06:45 PM
Stained floors
I just resfinished my hardwood oak floors it came out good for the most part but in one section of the floor there is a big blotchy spot in not sure where I went wrong this was my first time doing this any one have any advice on what to do to fix this
Old 01-14-17, 07:03 PM
XSleeper's Avatar
Received 1,720 Upvotes on 1,544 Posts
Could be uneven sanding and the dark area was rougher.
Old 01-14-17, 07:20 PM
That's what I was thinking.. you think the only way to fix it is by resanding and doing it all over??
Old 01-14-17, 07:28 PM
XSleeper's Avatar
I would take 5 minutes and try sanding a small area down with a palm sander and restain it to see if it helps. If some areas were drum sanded with 60 grit, for example and other areas were fine sanded to 120, the 60 grit areas would turn out much darker.
Old 01-14-17, 07:54 PM
Ok I'm going to give that a try. Thanks I appreciate the advice
Old 01-15-17, 03:14 AM
Received 742 Upvotes on 648 Posts
I'd try sanding those areas first with an orbital sander with 120 or slightly finer sandpaper. Sometimes a light sanding is enough to get it to blend. If a light sanding doesn't even it out, then sand deeper and restain.
