Transition molding
Old 02-14-17, 04:44 AM
E
Transition molding
I'm replacing carpeting in a bedroom with laminate flooring. What sort of transition molding is best for the area where the laminate meets up with the hallway carpeting in the doorway?
Old 02-14-17, 06:50 AM
Received 125 Upvotes on 110 Posts
Tee molding.
Going to need to install it between the door stop molding so you only see one type of flooring on each side of the door and install a carpet tack strip under the carpet to hold it in place.
Also best to undercut the door stop molding so the ends of the strip do not show.
Old 02-14-17, 07:24 AM
E
Perfect!
Thanks JoeC
