Cutting installed hardwood
Received 0 Votes
I am installing a new sliding door on the back of my house and I'm pretty sure the new door is a little bit thicker than the aluminum one from the '80's. This will require that I cut the flooring back a bit and I was wondering if there are any tips/tricks for this. Type of saw recommendation, tooth count on blade, anything that helps result in a nice smooth cut and doesn't mess up the floor. Much appreciated
A circular saw with a 40 + tooth blade will make a clean cut. Use a straightedge and set blade depth same as wood being cut. Probably will have a couple of inches that saw will not reach. I would use a oscillating saw to finish cut. Use straight edge on that cut also.
I use a 3" circular saw, I guess a full size one would work also as long as you trust the depth adjustment. I would practice cutting the exact depth minus about 1/32".
Sticking Velcro on the saw's bottom plate will protect the floor and make cutting easier.
The reason I use a 3" saw is because it can plunge cut. Be careful of kickback when plunging a regular circular saw down into the floor. The saw might kick back strongly.
