Steps make a ton of noise.
Old 04-05-17, 12:35 PM
E
Received 5 Upvotes on 5 Posts
It doesn't bother me all that much but my wife has decreed that it shall be my next project
The steps appear to be solid pieces of wood which are either nailed beneath the plugs or just glued.
Here is a pic.
And here is a video with sound so you can hear the creaking https://youtu.be/nscXz6Lwc-Y
So, any ideas? What causes this kind of creaking and, to start with, how do I take it up with out damaging it?
Old 04-05-17, 02:14 PM
Received 800 Upvotes on 703 Posts
Do you have access to the bottom side of the stairs?
Old 04-05-17, 02:54 PM
E
No I don't. Should have mentioned this is a concrete staircase.
Old 04-05-17, 03:43 PM
What do you mean by concrete...... poured, precast? The wood steps sit on top of concrete steps? Can you drill out a plug to see if there is a nail or screw under the plug? Creaking can occur when the wood step rubs against the nails that are securing them.....but right now you don't know if nails are involved. Need more info on the step framing, etc.
Old 04-05-17, 03:47 PM
How is the wood attached to the concrete?
Old 04-05-17, 04:36 PM
E
I don't know how it's attached. That's why I'm wondering what the best way to take them up without damaging them, so I can inspect what's going on.
How would I drill out the plug?
Old 04-05-17, 04:46 PM
Drill bit slightly smaller than the diameter of the plug. Drill slowly in case there is a screw in the plug hole.
Old 04-05-17, 06:47 PM
E
Can the plugs be easily replaced? Are they designed as a separate part? Sorry for my ignorance.
Old 04-05-17, 06:56 PM
The plugs could be made from solid wood or are a wood filler. They can be replaced. Depending on how they were installed e.g. glued solid plug or a filler the hole may have to be cleaned up or slightly enlarged if it gets chipped or dinged. You can replace them with another plug or filler. If there are screws or nails under the plugs you will have to deal with them as part of removing or fixing the stair treads.
Old 04-05-17, 07:16 PM
E
ok done, I drilled down about a 1/4" or less before I hit what is clearly a nail head. Made a bit of mess of it. What now?
Old 04-06-17, 05:31 AM
I'd try taking a flat bar and carefully pry the treads up. You need to make sure you don't pry hard against the risers and damage them. Might need a block of wood resting on the tread below to pry off of.
Old 04-06-17, 08:35 AM
Are the treads nailed into concrete or wood? Not sure what will happen if you try to pry up if you don't know if there is adhesive in addition to the nails. To minimize possible damage you could get a hole saw slightly larger than the plug and cut around the nails.
Old 04-06-17, 10:06 AM
E
I don't know if there's anyway to tell what they're nailed to without taking it up. When I get home this evening I'll give mark's suggestion a try.
Old 04-06-17, 10:22 AM
It's possible that the treads were tap conned to the concrete. If that is the case they won't pry up without damage BUT it shouldn't be hard to tell if prying is a viable option.
Old 04-06-17, 03:43 PM
Before trying to pry a tread up maybe try this. Drill out all 4 plugs on a noisy tread. Take a nail set and hammer each nail head. Test the tread for noise. If this stops the noise use some countersunk trim head screws to hold the treads tight. It is possible that the treads are moving up and down on the nails and making the noise.
