Varathane oil-based polyurethane alternative
Received 0 Votes
I just found out that California has banned the Verathane oil-based polyurethane that I was planning to use on the plywood floor in my shed. Does anyone know of a Calif legal product that's as durable and long lasting as the oil-based polyurethane and gives the flooring an "amber tint"?
I'd suggest going to your local paint store [not paint dept] and discussing it with them. I have no idea what is available [or not] in California. With hardwood if you want the amber look without using an oil base poly you need to apply a light stain first.
Personally while I'd want the shed floor to have some protection I wouldn't be overly concerned with the look.
Received 0 Votes
Update: I ended up using a light stain followed by four coats of water-based polyurethane (Varathane brand). After almost a month of fairly heavy use it seems to be holding up well and I'm happy with the appearance.
