Parquet floor lifting - looking for suggestions
Received 0 Votes
Hi,
My rental townhouse has some relatively old (~30 years?) parquet wood floors (6"x 6" squares, tongue and groove). As the weather warmed up my tenant noticed a section in the middle of my living room where a line of the squares were lifting up at the joints, creating a small arch.
I've removed the section of squares where they were lifting up (see pic). Obviously this is an expansion issue in warmer weather, but I don't want to remove the all the baseboard and cut back the edges - which is much more involved.
Is there a simpler strategy to fix just that area? My thought was to cut back some of the squares slightly (e.g., 1/8") to provide more clearance for expansion, and glue the squares down with adhesive. As long as the squares lay flat, the appearance doesn't need to be perfect since that area is always covered by a rug. Thoughts?
Seems a little odd that it would just start lifting now, wonder if something got spilt on the floor?
The parquet in my dining rm came in 1' square tiles [four 6" squares] and was glued down. I had 1 or 2 tiles that didn't stay stuck for some reason so I used my pneumatic staple gun to fasten them back down and puttied up the holes. That was 20 yrs ago and it hasn't lifted back up.
I don't think I've ever had to patch a parquet floor but would assume you'd do it like you would regular hardwood and cut off the bottom half of the groove. I've cut parquet with both a miter saw and table saw. Go slow so you don't rip out the little pieces of wood.
