What to do with laminate at the stairs
Greetings,
Hopefully someone can help. My son is installing laminate flooring directly on the subfloor. It originally had carpet. When the house was built, the previous owner planned to use hardwoods later on. Consequently, the very top of the stairs (casing) is 3/4 higher that the subfloor. The new laminate, with the additional pad only leaves about 1/8 inch between the top of the laminate and the top of the stair casing. The floor is down and there is not enough gap to put a threshold in and besides it would be too thick. My son wants to lay a bead of caulk but I hesitate. The gap is only 1/8 to 1/4 of an inch. I know that the floor needs to float. His argument is that the other end is free to move.
Can anyone bail me out with an idea?
Dave
Dave
Give more details, I am confused between height measurements and gap measurements.
Are you saying that the difference in height of the two floors is 1/8" or that the gap between the nosing and flooring is 1/8"?
I'd leave it as is. Put a piece of glass bead molding to cover up the gap between the laminate and the stair nosing. Glass bead molding is a very small corner cove molding that should work in your situation. Nail the molding to the stair nosing not the laminate. Make sure there is sufficient coverage for expansion on the opposite side of the laminate. Worse case is that the seam at the stair molding may show from time to time.
Prior to installation would have been the time to address, a trim piece around the opening with a cutout so the laminate could slip under and you would have been done.
Edges look pretty clean, maybe just leave it alone, right now you are focused on it, with time you wont even see it!
Hi guys,
I am not really good at this matter but last time I had to install laminate flooring, I occasionally found this blog post, it was useful https://www.hirerush.com/blog/how-to...minate-floors/
Later, as some additional questions occurred I turned to this website https://www.hirerush.com/ again and found some hands-on man who saved me some time by doing all the job.
Hope, this will be useful for you as well.
Regards,
Melissa
Regards,
Melissa
Marq1, I could not agree more. Where were you when I started Seriously, I wish my son had thought the project through before he started. I am now left with the clean up.
Check with a qualified lumber yard. They can order you whatever you need if it is not in stock. Remember, big box stores carry what sells, not necessarily what you need.
If a smidgen thick, break out the sander and hone it to the correct dimensions before you stain to match the rest of what you have.
Marq1, I guess I should have had my son come to the site for planning advice. To his credit, it was three rooms with an L shaped hallway. Not easy!
Thanks Marq1. I really do appreciate the answer.
