Parquet overlay
Old 03-24-18, 01:47 AM
Parquet overlay
Hi people
just a couple of questions i would appreciate some experienced advice in
1 can you lay 10mm parquet overlay blocks directly onto concrete like you can the 22mm blocks? If not why?
2 is it best laying unfinished or prefinished parquet blocks for cost? Finish?
Thanks
j
Old 03-24-18, 05:01 AM
Marq1's Avatar
Received 1,211 Upvotes on 1,099 Posts
Doubtful anybody really knows what you are referring to, can you provide a link to the material?
Old 03-24-18, 06:29 AM
Received 129 Upvotes on 114 Posts
Is this below grade, bathroom,or kitchen?
If so I would not do it for several reasons.
One wet event and it can be trashed.
That type flooring needs a perfectly flat surface, concrete almost never is.
Unless I was going for the 70's look I'd avoid it.
Old 03-24-18, 12:50 PM
https://www.directwoodflooring.co.uk...-flooring.html
first link is 10mm blocks
secind link is 22 mom blocks
apparantky 22mm Ines can defiantly be laid into resonantly level and flat concrete
some mixed messages about the 10mm ones
