Vapor Barrier over DMX+OSB?
Hi,
I am re-doing my basement floor and will be installing cheap laminate flooring from home depot. I installed DMX one-step on the concrete floor and above this I laid 3/4 in tongue and groove OSB.
My question is: should I
1. Include another vapor barrier between the OSB and the laminate planks or
2. Include (non-vapor-barrier) padding foam/felt between the OSB and the laminate planks
Thanks!
Eric
Thanks!
Eric
