About to lay floor - tips for electrics access?
Hi,
I'm nearing completion of a attic conversion and about to lay down flooring (probably tongue&groove) in the new space. I've had the electrics in the floor (e.g. in the ceilings of the rooms below) replaced but was wondering if there are any tips on making it easier for anyone in the future should they need to replace electrics/light fittings etc. in the room below?
Putting down floors (especially tongue&groove) feels very permanent
Cheers, Neil
Cheers, Neil
Welcome to the forums Neil!
Unless I misunderstand the question, not having access to the electrical from above would be no different that any other 2 story house. Normally the only access needed is at the box. Worst case scenario you'd cut and remove a portion of the ceiling to redo/alter wiring and then patch the ceiling.
When it's a ceiling I have done tiny labels and placed them on the ceiling where there is a fixture or plumbing cleanout or important something above. In 17 years nobody has ever spent enough time looking at the ceiling to spot them but they are very helpful when you need to come back at some point in the future.
On the floor I usually make a map. I do a drawing of the room layout showing the walls, doors and windows so it's easily recognizable what it is. Then a measure and mark the location of fixtures and important things buried in the floor. Then I post the drawing on the back side of a closet door in the room.
Thanks
Thanks for the tips guys - exactly what I was looking for. Also I'll turn the electric boxes upside down so they can be unscrewed from brlow, wouldn't have thought of that.
Cheers N
Cheers N
Also I'll turn the electric boxes upside down so they can be unscrewed from below,
