To Ply or not to Ply
Hi all,
I am doing a reno to a 1960s townhome. The home had 1” strip hardwood. The hardwood was installed the length of the rooms. And in the strips were run the length of the hallway; which just so happened to be opposite the rooms. I removed the old 1” strip hardwood flooring to find that there was 3/4” plank boards. The boards are about 3.5” in width. The planks are installed on a diagonal. I then realized that the 1” strips were installed perpendicular to the joists and that is why the hall is different to the rooms.
The ¾” plank subfloor is in good condition. I removed any nails from the strip hardwood. I then hammered in the old nails and screwed in every plank to the joists (joists are 16” OC) with 2.5” flooring screws (5000 screws). I will end up taking a floor sander to the planks because I found that there is gritty grime on some of the planks (most likely because of the plaster that was installed in the 1960s on the floor and ceiling). I also want to get rid of any high spots (wood chips) because of the nail removal from the 1” strips.
So I want to install either ¾” hardwood (4 or 5 inch wide) or engineered hardwood. Here are my concerns.
1) I want to run the new hardwood in one direction. The direction will be parallel to the joists in the rooms. Is that ok? Or should I put ply on top of the planks? If I should put down ply suggestions on thickness?
2) I really don’t want to put ply down because that will change the height from the bathroom. Also there is a guard rail along the stairs and code states that the rail must be 48” high from the floor. The guard rail is old wrought iron and secured really well into a joist. I am trying to avoid removing the guardrail if possible.
3) Also I have one closet that I want to run the same hardwood in but the closet is on a concrete slab rather than sub floor. There is vinyl tile on the slab currently. I can see that the tile is glued on with a black tar type adhesive. Can I glue the hardwood right on the tile?
Thanks.
Thanks.
Running the flooring parallel to the joist on a single layer of subfloor runs the risk of your flooring having a "wave" to it. The joists are stationary, and sometimes there is a dip or deflection between the joists that cause the "Wave" to take effect. For that, it is always recommended that flooring be placed perpendicular to the joist system.
A large straight edge can guide you, but the deflection from body weight between the joists is something that you need to seriously consider. Single 3/4" on the diagonal, is the minimum standard for nail down. No guarantees on end result.
Can I block from underneath
Thanks for the clarification. I understand now. Can I block between the joists from underneath say every 16 inches with a 2x8 to prevent the wave?
If, it's a floating engineering floor it would not necessarily have the same requirements to be installed perpendicular to the joists, but you need to check with the manufacturer!
