can I repair a Polyurethane scratch in my hardwood floor?
Old 01-31-19, 11:59 AM
R
Hello I recently had my wood floors refinished with Polyurethane over the natural wood (no stain) when I was returning the furniture to the room I made a few scratches in the Polyurethane finish. Can I remove those scratches by lightly sanding the scratches and reapplying a little Polyurethane over the area? Thanks in advance.
Old 01-31-19, 12:34 PM
Received 753 Upvotes on 658 Posts
Yes, but to keep it from showing you need to poly an entire board. Just a dab of poly here or there is apt to show.
Old 01-31-19, 01:23 PM
Marq1's Avatar
Received 1,137 Upvotes on 1,031 Posts
First think, try a little automotive rubbing compound, that will work for scuffs like dog nails. Not working, then try a dab across the scratch might be enough to not catch your eye.
Worst case you have to lightly sand and cover the entire board as mentioned!
Old 01-31-19, 02:36 PM
Received 1,197 Upvotes on 1,152 Posts
Keep in mind this is getting much more into the art of wood finishing than science - my former mother in law could probably pull off this repair but it is beyond my level of kung fu.
Old 02-01-19, 02:44 AM
I forgot to add that the board needs to be lightly sanded so the poly will adhere well.
I don't know much about painting over rubbing compound but suspect you'd need to remove it with paint thinner prior to applying the poly. Not sure the poly would adhere to the rubbing compound.
