Wrong finish used on unfinished wood floor.
I used polyshades minwax product on my unfinished wood floor at the suggestion of the paint department at Walmart. The floor looks awful, about 400 sq ft. Now I am reading that it is not recommended for floors. But also read where some people have used it on floors. I am going to look at it in the morning but I am not happy with the way it turned out and I am sick over this. Any suggestions?
Welcome to the forums.
Yes.... I see it says not to use on floors. That may be because it doesn't hold up like a floor finish would. You said it looks bad..... how so ?
The pros will be by to add information.
Minwax polyshades
Minwax polyshades
Yeah that's not a good product to use on a floor. Not sure what else to add. It's not a very hard poly... that can be solved by adding a better floor poly over it. Not suggesting you do that though. But I'm guessing the problem is that it just looks bad. (Probably smeary looking?)
You will need to chemically strip and scrape it off. Not a job I envy doing.
The worst part is that you kept going after the first square foot... should have stopped after the first Sq ft if it didn't look right. Pretty common mistake, others have done similar things so you aren't alone.
It's not dried yet. I will look at it in the morning and hopefully figure out what to do. We live in a rural area and it is next to impossible to get any professional anything out here to do work so I am left to figure it out on my own, me and YouTube and Google I sent an email to Minwax, hopefully someone there can answer. What should I use to chemically get it off?
That finish has to go, you think you have a mess now, if you put something on top it will be even worse.
I know in hindsight it's obvious but everybody really needs to do some research on products they are thinking about using!
The main reason PolyShades is not recommended for floors is because the color is in the poly, as the poly wears so does the color.
The best fix would be to sand the floor back to raw wood and then restain using the correct type of stain, followed by 3 coats of clear poly sanding lightly between coats of poly. That sanding both promotes good adhesion, smooths out rough grain and removes any minor defects in the finish.
The big orbital type sanders are a lot more diy friendly than drum sanders. A buffer/sander will also work but won't get as close in the corners.
Fine might work but I'd be prepared to step it up to a medium grit. The PolyShades needs to be removed, you need bare wood for a penetrating stain to work. How many times has the floor been sanded and refinished?
