“Rubber” flooring for gym
Old 11-11-19, 08:37 AM
B
I am redoing flooring in my basement. Moisture not an issue. It will be several rooms (will use Vinyl or Laminate) flowing into a 15 x 25’ gym. I was thinking of going into gym with same flooring (for resale purposes), and then install a nice thick (?3/8-1/2”) rubber floor. There will be heavy equipment obviously.
1. What are my options i.t.o. the rubber floor? I like the black “industrial look)
2. Should I rather not put vinyl / laminate underneath, and just do rubber directly onto concrete floor?
Thanks for you’re valuable advice.
Old 11-11-19, 09:36 AM
P
Received 2,007 Upvotes on 1,799 Posts
Some rubber flooring will stain vinyl flooring underneath. If doing a rubber floor I would just go with that. When it's time to sell if needed you can remove the rubber and put down something else.
Old 11-11-19, 10:10 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
I have a 10x12 room in the basement with rubber gym flooring.
You can buy large sections, or I went with the 12x12 pieces with interlocking puzzle shapes.
They haven't moved and the only think I found was the texture of the pieces were a little different between boxes but I dont even notice it now!
You would not install this over laminate flooring, just the concrete!
Old 11-11-19, 09:24 PM
sam floor's Avatar
Received 31 Upvotes on 26 Posts
If you would decide to glue the rubber down,it takes a special adhesive.
askari voted this post useful.
Old 11-12-19, 06:12 AM
B
@ Sam Floor: Do you recommend gluing it down?
Old 11-12-19, 06:42 AM
P
I would not glue anything down unless you have to. A rubber mat should stay in place pretty well on it's own especially if you have some furniture or equipment sitting on it.
