Laminate in bathroom
Old 12-23-19, 07:00 AM
P
Received 14 Upvotes on 13 Posts
I am looking to replace bathroom floor. Currently is 1x2 tile. My options in play are tearing a out current floor and putting down a larger format tile or going with a plank laminate over the top of existing. The walls have 4x4 tile so between that and the tub, I am not sure how to cover the edge of the laminate where it meets the wall or tub. Any suggestions?
- Peter
Old 12-23-19, 08:15 AM
XSleeper's Avatar
Received 1,721 Upvotes on 1,545 Posts
At the tub I'd probably either butt and caulk or use a tee molding. At the tile edge I would probably use a bullnose (quarter round) trim tile right on top of the old tile/new floor, then grout it to match. At your doorway you would either use a t molding or a reducer molding, depending on the height in the hallway.
I have also seen vinyl cove glued onto the existing wall tile.
Old 12-23-19, 09:16 AM
Received 260 Upvotes on 233 Posts
Most laminate is not recommended for bathrooms so make sure that the one ypou choose has a warranty in a bathroom.
Old 12-23-19, 10:11 AM
sam floor's Avatar
Received 30 Upvotes on 25 Posts
I would not trust any laminate in a bathroom. Even the "water resistant" ones consistently fail.
Old 12-23-19, 10:17 AM
the_tow_guy's Avatar
Received 177 Upvotes on 139 Posts
Vinyl plank as an option maybe?
Old 12-23-19, 11:22 AM
P
Yes, vinyl plank flooring is what I was considering. I was wrong to use the term laminate.
- Peter
