Underlayment /laminate
Old 01-06-20, 06:30 AM
H
is underlayment required for click lock laminate flooring. Installer says he doesn't use.
Old 01-06-20, 06:53 AM
T
Received 87 Upvotes on 77 Posts
Unless your installer can explain why he doesn't use it, get another installer. Underlayment is used in a laminate installation for many reasons, and some are dependent on the type of subflooring and location. In short, though, unless the flooring comes with underlayment (and most don't), adding it is needed.
Old 01-06-20, 06:59 AM
Received 260 Upvotes on 233 Posts
Not always required if floor is perfectly flat.
Note that some laminate has the underlayment already on it.
Does make for a softer, quieter and often warmer floor.
H
One thing he mentioned is to much under may cause joints to seperate.
Old 01-06-20, 07:17 AM
XSleeper's Avatar
Received 1,721 Upvotes on 1,545 Posts
Zero information about the exact brand and product he is using, so it's hard to say. Grab the instructions out of a box if there is one and read it.
All the laminates I have ever used have the underlayment on the planks themselves. So it depends on the exact product you are using.
Old 01-06-20, 07:27 AM
H
This is a side job for him. But does this full time for flooring store. Plus he's a friend so it's all confusing me.
Product is DreamHome from LL. 12mm without underlayment attached that I purchased. The install doesn't specifically call out wood sub floor, but references if used on concrete to add about vapor barrier and below floor.
Everything I've read everywhere tells me it should be used.
Old 01-06-20, 07:28 AM
XSleeper's Avatar
So do you have a concrete floor? Or is it going over an existing floor? A little more info would help. You aren't giving us much to go on.
Here are your product instructions. https://www.lumberliquidators.com/as...dream_home.pdf
Old 01-06-20, 07:47 AM
H
No concrete. OSB floor, 20 years old. Carpet ripped up, no holes, good shape. One level home so no sound below or above to worry about or moisture. Dining room, living room, bedroom coverage. Thanks for the instructions.
Old 01-06-20, 08:10 AM
XSleeper's Avatar
Looks like no need for underlayment then. Installers usually know what they are doing.
Also, the instructions note:
Wood subfloors, do not place plastic sheeting film vapor barrier over a wood subfloor under any circumstances. Wood subfloors need to breathe.
Old 01-06-20, 08:47 AM
T
I'm missing your thinking here, XSleeper. Why is there no need for underlayment? The instructions say within the first few words:
Laminates without a pre-attached foam
underlayment will require a separate underlayment.
So, it seems to me that underlayment is required, but not a vapor barrier.
Old 01-06-20, 09:01 AM
XSleeper's Avatar
It has a pre-attached foam underlayment.
From the aforementioned instructions:
DREAM HOME Laminate Flooring consists of planks made from a durable laminate surface, a wood based core DREAM HOME Laminate Flooring consists of planks made from a durable laminate surface, a wood based core and a balancing backing.
You can also look up the product description on the LL website.
"Pre-glued underlayment is attached and its V-groove click system makes it a snap to install. Nothing else is needed to make this spectacular flooring a stunning floor!"
Old 01-06-20, 09:25 AM
T
XSleeper, I don't know. OPer posted later:
So I have no idea. Can we agree that underlayment is required? If the laminate comes with it, that's fine, but if not, it must be added.
Old 01-06-20, 09:32 AM
XSleeper's Avatar
I guess if he really has a product without underlayment then yes, it would need one.
Old 01-06-20, 10:37 AM
H
Thanks for help. I've gone back to LL and purchased 800 sq ft of QuietWalk underlayment. If my friend pushes back on using it i'll take it back.
I was just trying to be as sure as possible to have a beautiful long lasting floor after finally getting rid of the carpet I've hated for 20 years.
Old 01-06-20, 10:41 AM
XSleeper's Avatar
Hard to believe that if the flooring you picked out in the store needed underlayment that they didn't recommend and sell it to you when you bought the flooring! So much for knowledgeable salesmen!
Old 01-06-20, 12:39 PM
T
Sounds like you've made up your mind so I'll be brief. LL carries 12mm laminate with padding attached, including some Dream Home styles. Perhaps you could get that and avoid an issue. It seems a shame to end up with less than the correct flooring after waiting 20 years.
