Ranco Thermostat
Old 03-02-16, 05:57 PM
B
Received 111 Votes on 97 Posts
Ranco Thermostat
I would like a data sheet for a Ranco thermostat Model G1-1057, Can't find anything on the internet. It is located on the indoor coil of the heat pump and is wired to the heat pump/furnace control but not listed in any heat pump/ furnace documentation. I think is was installed by the HVAC installer because the HVAC is not a package system. I need to know the operating temp range, type of contact ( SPST, SPDT) and operation of contact (opens/close on temp rise, open/ close on temp fall). Thanks in advance.
Old 03-02-16, 07:36 PM
Received 1,480 Votes on 1,368 Posts
SPST TEMPERATURE CONTROL W/36" CAP. FIXED TEMP SETTING OPEN ON TEMP RISE.
Could not find anything on the temperature set point.
