How do I choose a thermostat?
Old 12-20-16, 07:47 AM
G
Received 2 Upvotes on 2 Posts
I recently had my old furnace replaced with a 2-stage one (NG). I had a pretty new programmable touch-screen thermostat but could never take advantage of the set-back possibilities bc the old furn would hit the limit and take forever to ramp the temperature up.
The installer upsold me to a wifi Sensi thermostat and I went for it mainly because after rebates I pocket $50...so why not? The box says it's compatible with 4 or 5 wire systems & up to 4 stages of heating (& 2-stage cooling). There's nothing whatsoever in the setup menus about configuring it for multi-stage. Should it--or does it just "do its thing" closing contacts and the furnace makes all the "decisions"?
Also--I have a flow-through humidifier & humidistat on the furnace & the thermostat has a humidity indicator on the display but no way to connect it to control the humidifier. Doesn't humidity control make more sense at the thermo than a dumb humidistat on the return duct?
Should I sell off the wifi toy and get a different 'stat?
Old 12-20-16, 08:19 AM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
hi, you didn't mention the exact model of the stat,one question I have is why the Genius that up sold the stat to you didn't take the time to help you set it up? it does appear there is a setting for 2 stage gas heat, double check the owners manual under contractor options or something like that.
Old 12-20-16, 11:04 AM
Received 3,748 Upvotes on 3,361 Posts
Step 4.... indoor equipment configuration.... needs to be set to GA2 for two stage gas.
sensicomfort/pro-install-manual.pdf
Old 12-20-16, 07:35 PM
G
Pete,
I guess when I changed it from Electric to Gas I did choose GA2. That's all there is to it...?
It's also set for 2-stage cooling (AC2). My AC is 8 years old... Is the number of stages set by the compressor or the furnace?
Old 12-20-16, 07:41 PM
G
Geo--there's only one model Sensi.
I wasnt home to get the tutorial... Didn't know my service call was going to end up being a new furnace. Besides--the guy who came out to troubleshoot the old furn split once the B-team got there.
AND I had told him not to install it.
If this wifi 'stat does everything needed I'd prefer to keep it. Wife likes it. VERY few buttons on the unit, and a simple uncluttered display.
Old 12-21-16, 07:37 PM
Tolyn Ironhand's Avatar
Received 811 Upvotes on 683 Posts
The furnace will determine the number of stages of heating. It will kick in a 2nd set of burners as needed. The A/C condenser will determine the stages of cooling. If the A/C is the same one you had before it will only be a single stage unit. Multi stage units will have multiple compressors in them.
Old 12-21-16, 08:22 PM
G
Thanks T.I.
Over time I've noticed quite a few posts seeking help with Nest wifi 'stats but I haven't noticed issues with Sensi. I'm hoping that's because they're OK.
Old 12-23-16, 09:35 AM
The Sensi is newer and not as well exposed. The nest has been around much longer.
Old 12-23-16, 10:27 AM
G
Can the Nest control a humidifier?
