Nest stopped receiving power from Goodman Furnace
Hello,
Last night (New Years Eve) the Nest thermostat read "wiring report no power to Rh wire detected." This morning I took the doors of the Goodman GMS80603AXBC to check if the fuse had gone out on the furnace but it was fine. I then pushed the door button and the solid red might clicked on but no power was delivered to the thermostat. Next I took out the multimeter and out of the 5 wires (Yellow, Green, Blue, Red, White) I tested White and red, Green and red, and yellow and red but none of them delivered any volts.
I would really appreciate any help
Thank you!
Thank you!
Welcome to the forums.
A meter is an excellent tool and can help us here.
Check for 24vac on R and C. Is it there ?
That Goodman furnace should have a trouble LED. You should be able to see it thru a sight glass in the door. What is it blinking ?
