Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Thermostatic Controls
Reload this Page >
Honeywell RTH3100C wiring. (AC is blowing Warm Air Instead of Cold Air)
Old 05-28-17, 09:36 PM
Exclamation Honeywell RTH3100C wiring. (AC is blowing Warm Air Instead of Cold Air)
Honeywell RTH3100C wiring. (AC COLD is blowing Warm Air Instead of Cold Air)
I need some help to figure what causing of hot air coming out even though it is set on AC COLD AUTO.
**Actually to be precise, it blows a little bit COLD AIR but after like 3 minutes or that weird sound "like something is getting activated" it stops blowing COLD AIR and then it starts blowing HOT AIR again.**
HEAT IS working fine.
I need help step by step, what tools needed and for safety precaution.
Thanks guys.
Old 05-28-17, 10:23 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
It sounds like your heatpump is going into defrost mode.
What brand is your outdoor unit?
The O wire looks like it isn't properly inserted.
Old 05-29-17, 08:45 AM
Here are the pictures. Thanks for the reply.
Old 05-29-17, 09:12 AM
Received 1,107 Votes on 1,027 Posts
Those pictures are the hot water heater. I removed them as they are of no help.
Your heat pump is the unit that sits outside and has the compressor in it.
A picture of it won't help. We need the actual make and model number of it.
