Replacing BAYSENS006 with regular stat
Old 08-10-17, 07:27 PM
F
Have a commercial A/C unit with an older thermostat. It works, but would like to install one with a display. I have a picture of the thermostat with the cover off and the wires exposed. The cover of the thermostat says Trane, and it looks like the BAYSENS006 (if you Google search, it should be the first result that says "Installer's Guide). Can you tell what type of thermostat I would need to replace this one?
I did try a conventional one and the wiring did not match the terminals,so I sent it back without trying it.
Old 08-10-17, 09:12 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
I would remove the panel on the package unit to see if is has conventional terminals as well as those proprietary terminals.
Old 08-10-17, 10:45 PM
Received 1,203 Votes on 1,113 Posts
Now that was strange.
I posted to this thread 2 hours ago after I updated the title and it's not here.
Anyway... welcome to the forums.
