Help adding simple wifi control to simple wall heater
I have one of those questions that seems straight-forward - which probably means that it isn't.
We have a small cabin that I plan to start using as my office. It is one room and is heated with a simple wall heater/fan unit. It has a rudimentary dial thermostat with no digits - just a gradient from cold to hot.
I'm wondering what the simplest way would be to connect the unit to wifi so that I can turn it on from the house. It doesn't even need full thermostatic control really - just an on/off toggle would do.
The situation is slightly complicated by the fact that the walls are pine T&G, making it difficult to run new wires. So if the connectivity could be installed right in or near the heater, this would be ideal. Although I realize that such a setup is likely to be heat sensitive.
Thoughts? Brainstorms?
Thanks!
Thanks!
If it's run via 120v AC then you can buy a plug in module with WiFi ability. Just need to make sure the amp draw will be sufficient. I have one that is stated as being rated for appliances, but I never looked at the amp rating. I use for lighting only.
Welcome to the forums.
Your heater is 500 watts. The biggest problem is that it's hardwired. That is something that will need to be addressed. There is nothing I know of that will go directly inside the heater.
The Atmoz wifi is a line voltage wifi enabled stat.
king-electric/product-line-voltage-thermostats.php
