Install after-market Thermostat to Carrier Edge System
Received 0 Votes
I've been able to find a few articles related to this on this forum, but I want to just get a better understanding of what I would need to do to install a Nest or Ecobee thermostat. My system is carrier, so I have the control module that feeds the V+ and Vg wires from the furnace in the basement up to the one thermostat in the dining room. See below for an image of the module by the furnace. The thermostat has the green, cyan, yellow and orange wires tucked behind it. How exactly do go about rerouting the wires from the thermostat around this control module? Is it something I can do without running new wires? Is it as simple as disconnecting the V+ and Vg wires from the left side of the control module and connecting them into that right side?
Welcome to the forums.
When you mess with a thermostat you need to know your system.
It looks like a heat pump system with back up electric heat.... is that correct ?
How many wires are at the thermostat ?
You will need at least 6 wires.
Received 0 Votes
Thank you.
And yes, it is an electric heat pump with back up electric. There are 8 wires behind the thermostat. The Red and White, which currently serve as the Vg and V+ for the Carrier Thermostat, and then unused Cyan, Orange, Yellow, Green, Brown and Black wires.
I'm seeing what I think is an AUX connection in the bottom left. I believe the red is a short jumper to Rc. Do you have a humidifier ?
Sorry.... I responded and my post isn't here.
So that's a yes on the humidifier ?
You'll need to unwire that EIM but you do have enough wires
to install a wifi stat like the nest 3, ecobee 3 or higher.
Received 0 Votes
Yes on the humidifier. I was able to successfully set up a Nest Learning Thermostat last night. I unwired the control module, and connected the wires coming from the outside heat pump, furnace and thermostat. R to R, W to W, etc.
My Carrier Edge was actually on the fritz, and couldn't communicate with the furnace, which is what prompted this change. Taking out the control module seems to have done the trick, because my house is no longer under 60 degrees.
Thanks again for your help.
