Trane to VINE thermostat
Old 03-09-18, 08:35 AM
ronxlau's Avatar
Question Trane to VINE thermostat
Hi,
Im trying to install a Vine Smart WiFi Thermostat with 7-Day Programming, Touchscreen and Nightlight (TJ-610) to a TRANE A/C and Air Handler TWE048P13BF0 ( 4 Wire connection).
I have taking pictures of the before connection like it recommends on the VINE installation manual, i turned off the breaker for FURNACE and A/C. I connected the wires as indicated), but i noticed that when the FAN turned on the VINE Thermostat re-initiated itself (like a power recycle) i figured i did something wrong. So i checked again and noticed i had to go in the Air Handler and make an adjustment. Like in the video:
https://www.youtube.com/watch?v=FvsCIKdJsc0
But i dont know where this wiring is located on my Air Handler, i still havent opened the Air Handler, i need to know where those cables are located before i attempt to open it.
If anyone has any owners manual/guide about the TRANE Air Handlers i would appreciate it.
Old 03-09-18, 12:40 PM
You find those connections in the blower section.
Old 03-09-18, 10:00 PM
Received 3,897 Upvotes on 3,494 Posts
That thermostat needs a C connection to operate.
What do you have..... a split A/C with electric furnace ?
The Trane TWE shows as a heat pump system.
Are there any spare wires in that thermostat cable ?
A picture of your old stat connected or what color was on which terminal would be helpful. How-to-insert-pictures
Trane multi air handler
Old 03-11-18, 09:39 PM
ronxlau's Avatar
Added image of Old thermostat conneciton
Thanks PJMax,
To respond to your questions:
Yes i do have split A/C and Furnace.
I dont see any heat pump, looks like a standard Air Handler.
No spare wires, just a second cable that i explain below with the images of the current (OLD) thermostat.
Attached are two images of the old thermostat, one showing the cable positions.
G goes with G
W goes with W
Red goes to RH ( Then a small black cable from RH to RC)
Blue goes to Y
Additional to this, the other image shoes two sets of cables going to the thermostat and Air Handler, meaning cable #1 ( has 4 wires (R,G,BL,W), cable #2 (has 2 wires (R,W)
Cable #2 wiring:
R goes to Y position
W goes to Y cable in Thermostat.
Last edited by ronxlau; 03-11-18 at 09:48 PM. Reason: adding more clarity to current connection
Old 03-11-18, 09:51 PM
ronxlau's Avatar
Thanks Skaggsje
I opened the air handler and there it was, the 24v cables going out of the furnace electrical box
3 White wires (WH1,WH2,WH3) + 1 24v White wire
1 Green
1 Blue (my Y i guess)
1 Red
No extra wires, no Terminal C.
Old 03-12-18, 12:55 AM
Since you have an electric furnace..... you cannot use that 4 wire connection method shown in their video. You need to have the blower controlled by the thermostat. There is a C connection at the air handler.
You must have either 5 wires or you can purchase a C maker module like the Fast Stat 1000.
Rheem-1000-FAST-STAT-Wire-Extender
That extra two wire cable in the wall appears to be from an overflow float switch for the A/C condensate pan. How did they get cable to the thermostat ? It may be easier just to run a new thermostat cable to the air handler.
Old 03-13-18, 09:49 AM
ronxlau's Avatar
Hi PjMax
Please can you tell me where in the diagram connection the C connection is, i can definitely throw a new cable to the thermostat. thermostat and Air Handler are next to each other. Just need to buy the right cable and length
thanks,
RL
Old 03-13-18, 11:39 AM
I don't see the requested picture for the wiring at the air handler. There should be two cables there. One goes to the thermostat and one goes to the outside condensor. We need to see those splices.
Old 03-16-18, 08:49 AM
ronxlau's Avatar
Images from the Furnace side
Hi PJMax,
I added some pictures i took from the furnace in hopes that you can see the C connection. I dont know if this will help, or if you need more pictures. Please let me know.
Thanks,
Ronxlau
Old 04-19-18, 07:23 PM
ronxlau's Avatar
Hi PJMax,
I did add the pictures a while back, can you please review them, i also purchased the Rheem-1000-FAST-STAT-Wire-Extender but i still need to find the C connection to complete the installation.
Thanks in advance
Old 04-19-18, 08:39 PM
If I don't respond.... please feel free to "bump" the thread.
The blue wiring in the picture is Common. It connects to the metal chassis at the transformer so the entire metal frame is C. The blue wire goes down to that white plug. The blue connections with the wirenuts should also be C. All the C blue wires will be connected.
