Help installing Honywell T5
Old 11-15-18, 03:37 AM
R
Size:  86.9 KBName:  Trane1.jpg
Size:  34.2 KBI currently have Trane Thermostats and would like to replace them with Honywell T5+ 's. My HVAC system uses split compressors and air handlers with Electric heat. I see I need to change cable to include a common C , no problem with that but I am trying to sort out the blue and yellow leads on current Trane Thermostat.Photos of Trane Thermostat and terminal block in handler attached
Old 11-15-18, 08:58 AM
R
This is the missing photo of Trane terminal block. Trying to understand what the blue and yellow leads do
Old 11-15-18, 03:02 PM
Received 1,595 Votes on 1,470 Posts
Welcome to the forums,
Based on the stat end. Can't see the connections clearly on the air handler end.
I see a wire on O at the air handler that would suggest a heat pump system.
R - red - R
W - white - W
Y - yellow - Y1
Y2 - blue - Y2
G - green - G
Old 11-20-18, 09:11 AM
R
Thanks very much for the replyam trying to replace Trane thermostats with Honeywell T5's. Question:I understand the C,G,Y,W and R connections but on my Trane there is also a blue wire connected toterminal Y2 on the thermostat and going to terminal Y on the control board. The yellow wire goes terminal BK on control terminal. The yellow comes from Y on the Trane thermostat. There is a Y2 , unused, on the terminal board.Trying to understand what terminal BK is all about and why the yellow wire from Y on the Trane thermostat doesn't go to Y on the control board instead goes BK and Blue goes to Y.
Any Ideas?
Old 11-20-18, 08:23 PM
If you look at the thermostat wiring and the wiring at the terminal block. They don't match. The same exact type of wire is not at both ends. That means there is a splice somewhere you'll need to find.
