Help with T5 installation
I installed the T5 lyric last week. Needed to turn on the A/C tonight and it's blowing out heat. Went outside and saw my unit is on and working, and blowing out cold air from the top. Turned off the lyric and then turned the breaker off to check wiring. Need help though with this.
Top picture is old thermostat wiring. Bottom is new one.
Welcome to the forums.
The white wire needs to be in AUX/W2 for proper backup heating. You could take and splice on two small pieces of wire to the white wire and put one in AUX/W2 and the other in E. The E runs the electric heat without the heat pump running.
You need to setup the Lyric for your system....
function 200 - system type - heat pump
function 205 - equipment type - heat pump/air to air
function 218 - reversing valve - O/B on cool
function 220 - cool stages - 1
function 221- heat stages - heat stages 1 and Aux/E stages 1
You download the app. Register the T5 and it can be changed in the app.
Lyric T5
If you don't have the app...... when first powering up the stat.... you'll see start setup.
Then you'll see setup app. If you aren't setting up the app..... select NO and the next step is conventional. The functions I left are in conventional setup.
Lyric T5
1. Start Setup with app. Touch START SETUP on thermostat.
2. Select to setup with app. Touch Yes on the SETUP APP screen.
3. Log in to configure and connect.
Your Lyric thermostat is not yet configured to control your heating/cooling system. To setup your system, download and open the Lyric app, and then touch “Install Lyric T5 Now”. If your thermostat does not appear on the screen, tap ‘Install a device’ and follow the prompts to continue.
Your old stat was using the O valve connection which means it gets powered for A/C. If it's not powered..... you should be getting warm air from the heat pump. To confirm this..... you could temporarily remove the orange wire from O and see if you get heat then.
Per your PM...... I labeled your Lyric base in the second picture. The terminals in blue box are for the heat pump operation. The terminals in the pink box are for conventional.
So W and W2 in the pink box are for W1 and W2 heat on a gas furnace.
Aux and E in the blue box are for the heat pump heat. AUX is backup electric heat and E is emergency heat.
