Sensi + humidistat wired together ?
Old 12-29-18, 11:03 AM
I presently have a non-programmable 4-wire thermostat and a 2-wire Humidistat (Florida).
Can I connect the wires from both units to the Sensi WiFi Stat ? If so, to where do the 2-Humidistat wires connect in the Sensi?
I have an unattached blue wire ('C" - ?) if required?
Please advise asap.
Separated from...... wiring-de-humidistat-control-emerson-sensei-wifi-thermostat
Old 12-29-18, 12:34 PM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
I started a new thread for you. Two members in one thread can be confusing.
The Sensei doesn't control humidity directly and there is no direct connection to it. You can set the humidistat up so that the humidity would have to exceed it's setting for the A/C to run.
Old 12-29-18, 04:47 PM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
Please advise asap.
Better off with a nest, ecobee, or a vision pro 8000 to control humidity directly..
