Smart thermostat for taco controller
Old 01-14-19, 04:30 PM
P
I have hydronic 5 zone heating system in cold weather vacation home. I have installed go control z waze thermos in each room do that I can monitor and adjust temperatures. I installed them as battery only however they can run 24volt. The issue is I only gave 3 wines available. Only two wires are used to activate the taco valve control. Question is can I use the unused third wire and the white wire to supply 24 volts? When these batteries die the system shuts down do I need to be failsafe...
Old 01-14-19, 04:49 PM
Received 3,753 Upvotes on 3,365 Posts
Welcome to the forums.
You may be able to get the needed C connection from the Taco controller but we need to see a picture of it first. There are many variations and some don't have a C connection and some have too small of a transformer.
How-to-insert-pictures
Old 01-28-19, 05:43 AM
P
Photo of taco controller
Thanks for the reply, I will send photog next Errol ad the system is at a remote location.
