Old Thermostat Color coding
Old 04-23-19, 12:10 AM
G
I tried changing the thermostat to a new one, but it was not compatible with my system.
I need help trying to reconnect the wires back the way they were.
The ac is still not working property.
Old 04-23-19, 01:03 AM
Received 1,118 Votes on 1,038 Posts
You're supposed to take the picture of the wiring before changing it.
Added a thermostat wiring chart to your pictures.
Pretty sure you have a heat pump system there but we need more information. Since the B terminal is in use..... that would signify a Rheem/Ruud A/C system. Is that correct ?
Red on Rh and Rc
Brown on G
Yellow on Y (jumper required from Y to W)
Blue on B
On a replacement stat......
Red to Rh and Rc
Brown to G
Yellow to Y
Blue to O/B and set for B heat pump operation (if Rheem or Ruud)
Configure stat for heat pump operation with no backup electric heat.
