Help with common wire for 3rd gen nest
Old 07-05-19, 05:09 PM
F
First time posting in the forums but read many other threads like mine but wanted verification as I'm not super handy with electrical. I want to install a nest 3rd gen but read the possible issues of the power stealing it would do and want to just avoid that headache if possible. Upon removing tstat I only have a r and w wire with a unused g wire. My hopes are to use the g coming off my 3 wire as my c since its not being used anyway.
With the pictures below can I plug the g wire directly into the yellow Power In 24vac? I don't have a voltmeter at the moment.
Any help would be great!
Old 07-05-19, 09:06 PM
A
Received 91 Upvotes on 83 Posts
Yes, you need a voltmeter/multimeter to figure this out as these Taco boards are not consistent with their configuration. Harbor Freight usually has a multi-meter cheap.
Follow this thread: https://www.doityourself.com/forum/t...hermostat.html
Old 07-06-19, 07:54 AM
F
Thank you. Just because I'm unsure about what to exactly test, would I place positive lead on the yellow Power In wire? And my negative on what?
Old 07-06-19, 08:19 AM
A
When on the AC scale positive and negative don't matter. Follow the step-by-step instructions provided by PJmax in post #4 of the link above.
Old 07-06-19, 01:15 PM
Received 3,593 Upvotes on 3,222 Posts
Welcome to the forums.
On the 403.... the R is fused which leaves the yellow as C. Always good to check anyway.
