Honeywell T9 installation
Old 10-16-22, 08:47 AM
W
Hello All. I am a homeowner attempting to replace my current Honeywell thermostat with a new Honeywell T9 smart thermostat. I think I have it figured out but I just want to be certain before removing my current thermostat.
Here is a picture of the wiring for the current thermostat. Itís only connected to my boiler in the basement, no central AC:
Current thermostat wiring
I traced the wiring to the boiler in the basement and here is what that looks like:
Wiring at boiler
The blue wire in the photo is folded and not connected to any terminals (as it is in the picture of the wiring at the thermostat). My question is: Can I simply strip the top of the blue wire and connect it to the W terminal and then connect it to the C terminal at the thermostat?
Thanks for any help I can get in advance.
- Warren
Old 10-16-22, 11:34 AM
Received 3,897 Upvotes on 3,494 Posts
Welcome to the forums.
The picture below represents your aquastat and it's connections.
Yes.... you can put the blue wire on Z or W and use as a C connection.
You must put your red wire on TV and R at the thermostat. (put slider in 1 wire position)
You must put your white wire on T and W at the thermostat.
Old 10-16-22, 12:09 PM
W
Thanks. I will try that.
Thanks for your help. Iíll give that a shot.
