Replace Toilet Supply Pipe Escutcheon
Old 03-06-16, 11:12 AM
E
I am installing a new toilet and would like to also replace the rusty supply pipe escutcheon. What would be a good repair that will look decent and reduce labor if possible: 1) replace with a two piece escutcheon (I have heavy tin snips for removal of old escutcheon) , 2) remove the shut-off valve be and replace with a single piece, 3) remove old escutcheon and cut the single piece and bend to fit the new one.
Any other info appreciated for this job is welcome.
Two piece
Everbilt 0.5 in. Copper Tube Size Pipe Escutcheon-C5340C - The Home Depot
Old 03-06-16, 11:18 AM
Received 321 Votes on 285 Posts
How much work do you want to do? They sell the 2 piece escutcheon plate because it means a lot less work.
Old 03-06-16, 11:22 AM
XSleeper's Avatar
Received 676 Votes on 625 Posts
Personally I use the standard escutcheons by removing the shutoff, slipping on the new escutcheon, then put on a new compression shutoff. Hold it all back tight to the wall as you tighten the compression ring down. If the shutoff won't go back far enough to hold the escutcheon tight to the wall, then the stub is probably just a little too long. Measure how much farther it needs to go back, cut the stub a little shorter, and you're in business.
Old 03-06-16, 11:29 AM
Received 77 Votes on 72 Posts
Those valves only last so long and then they tend to get stuck, plating comes off and leak at the stem.
Far better to just replace the valve with a new 1/4 turn valve and escutchen at the same time.
Old 03-06-16, 12:16 PM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
they have plastic chrome ones with a spit that I use.. Looks nice..
Sioux Chief 1/2 in. x 2-1/2 in. Escutcheon-HD926-2PK2 - The Home Depot
