Removing cast iron bathtub
Old 03-24-16, 12:01 PM
R
I think my bathtub is CI , sounds like a bell when tapped ,is dark and rough looking at the bottom from the basement and the walls are thick
I need to remove it. Is there another way besides braking it apart with a sledge ?
Thank you
Old 03-24-16, 05:07 PM
P
Temporarily Suspended
You could try to cut it with a sawzall & a carbide blade.
Old 03-24-16, 05:24 PM
Received 3,607 Upvotes on 3,234 Posts
A sawzall would work but be very time consuming.
You could also use a cutoff grinder to cut the tub.
I've only ever used a sledge hammer. Nailpops do occur below with this method.
How to Remove a Cast Iron Bathtub | DoItYourself.com
Old 03-24-16, 05:44 PM
P
I was thinking the same thing. I was going to say that he should be done memorial day.
Old 03-24-16, 06:00 PM
Handyone's Avatar
If you end up having to use a sawzall, use a Milwaukee blade called "The Torch". They cut very well.
Old 03-24-16, 07:47 PM
R
Thank you all for replying
I think I ll tray the sawzall method first with a 10 lb sledge standing by.
Old 03-24-16, 11:57 PM
P
The Torch & that Ax are very good blades. They may not cut cast iron though unless you have done it before. A carbide blade maybe needed.
