Thoughts on reinforcing a shower stall
I am not a small person, and I have seen fiberglass showers and tubs crack with regular use and end up leaking.
I am looking at buying a place that has a shower stall in it, and I am concerned about it developing a crack. The porcelain on metal shower pans I have seen are rather expensive, and I had a thought to reinforce/build up the fiberglass.
First, start with setting some decorative small stones in epoxy, then putting 2-3 layers of clear marine fiberglass over the top. Similar to what is used on wood kayaks.
Any thoughts on this?
Any reinforcement would have to come from support below, not build up from above. Many are set in a bed of cement when installed unless they are designed for self support at the factory.
