Blocked shower drain
Old 11-11-16, 05:19 AM
A
My shower drain seems to be blocked. I was able to remove hair and gunk build up from the surface of the drain, but the problem has not been resolved.
It seems the blockage is down deeper.
When the shower is run there is a build up of water in the basin of the bath. And soon your feet are completely immersed.
I got this little wire tool. Has anyone tried using one of these before on a shower drain. Can it be resolved easily, or do you think I should get a plumber?
I think i may have to remove the drain surface plate before using the tool.Name:  Wire Tool _01.JPG
Any tips??
Old 11-11-16, 05:49 AM
P
Received 619 Votes on 572 Posts
Well, you've got a drain auger in your hand. Have you tried it?
Where the clog is can depending on whether or not you have a shower only or a tub and shower. Tubs often have a drain stopper built into the piping underneath the tub. Clogs often occur there. The snake/auger can often get the clog but sometimes you need to remove the stopper. Dedicated showers do not have a drain stopper so clogs are often in the trap.
Old 11-11-16, 05:52 AM
Received 77 Votes on 72 Posts
May be better off with one of these.
Zip-It Bath and Sink Hair Snare-BC00400 - The Home Depot
Old 11-11-16, 05:54 AM
C
Received 2 Votes on 2 Posts
You may want to try one of these:
They cost a couple of bucks and work pretty well if the clog is close to the drain (likely). Especially good on hair clogs, which are common in showers and tubs.
Old 11-11-16, 08:11 PM
czizzi's Avatar
Received 14 Votes on 12 Posts
Snake through the overflow opening not through the drain opening.
Old 11-12-16, 05:17 PM
Since when does a show drain have an overflow?
