LED fogless lighted shower mirror?
Old 01-04-17, 04:32 PM
I just bough the LED Fogless Lighted Shower Mirror is guaranteed not to fog while I'm grooming myself in the shower. Do I use rubbing alcohol on the tile before installing the silicone adhesive,
https://www.bedbathandbeyond.com/sto...=shower+mirror
Old 01-04-17, 04:37 PM
Received 1,315 Votes on 1,215 Posts
Do I use rubbing alcohol on the tile before installing the silicone adhesive?
Yes. You MUST clean the tile so that the self stick pads and silicone will stick.
I only use lighter fluid for this purpose as it leaves NO traces behind and it's an excellent cleaner.
Old 01-04-17, 05:31 PM
Can I use 50% rubbing alcohol? Is it too strong?
Old 01-05-17, 06:43 AM
P
Received 742 Votes on 683 Posts
50% rubbing alcohol may be on the light side. I only use 90% rubbing or 100% denatured alcohol. Whichever you use I'd use a white cotton rag and thoroughly clean the area until your rag comes away white. If you keep getting color on your rag you've still got more dirt and soap scum to remove.
