Cracked toilet flange repair products
Old 03-04-17, 09:52 AM
the_tow_guy's Avatar
Received 200 Upvotes on 160 Posts
Doing a reno on our hall bath and when I got toilet out discovered the flange has a crack on one side right where the bowl hold-down bolt goes. Any of the pros have a particular repair system they like? This is PVC in slab.
Thanks.
Old 03-04-17, 11:51 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
You'll have to tapcon it to the concrete, but this will help hold down the toilet where it is cracked. Sioux Chief Stainless-Steel Flange Repair Ring-886-MR - The Home Depot
Old 03-04-17, 02:07 PM
Thanks, Larry. Yeah, I figured anchoring into the slab was in the job. Your link is cheaper than the one I was looking at that looked a bit over-engineered, like it was made to anchor the head on an aircraft carrier:
Like Roseanne Roseannadanna always said, "It's always something!".
[ATTACH=CONFIG]77860[/ATTACH]
Old 03-04-17, 02:37 PM
XSleeper's Avatar
Received 1,813 Upvotes on 1,630 Posts
Don't know if your flange is currently raised or flush with the finish floor, but if say tile has been added around the original flange thereby raising the height of the finish floor above the flange, a simple pvc flange spacer ring might also work.
