Single level home: low water pressure in shower
Old 04-26-17, 06:28 AM
Can a different shower head make the difference? None of them have any water pressure rating on them. Would like to know if any have a feature to constrict the flow (like you do with a garden hose to get less water come out at a higher pressure)?
Old 04-26-17, 06:49 AM
D
There are water saver shower heads. Water Pic has a shower head in Home Depot for about $20 that will give you full pressure.
Old 04-26-17, 07:06 AM
Received 319 Votes on 283 Posts
I live on top of a tall hill and deal with low water pressure all of the time I bought one of those water saver shower heads and it seems like I have better pressure than I did when using a regular shower head. I don't recall what it cost but it wasn't expensive.
Old 04-26-17, 08:09 AM
P
Received 625 Votes on 578 Posts
All shower heads are limited by law to flow no more than 2.5 gallons per minute. Some "water saving" models are designed to flow even less. Picking a shower head that allows the full 2.5 gallons per minute will give you more water.
Best Showerhead Buying Guide - Consumer Reports
If a new shower head does not solve the problem I would remove the shower head completely and turn on the water. How strong a flow do you get from the pipe with the shower head removed? If it's weak you may have a partially clogged faucet or some other restriction.
