Quick kitchen sink question
Old 04-28-17, 06:57 AM
H
Received 3 Upvotes on 3 Posts
I just replaced old, not done correctly, piping under my kitchen, including the strainer basket. I used PVC. Everything is fine except the basket to the first piece of drainpipe has a very tiny slow leak. The washer that came with the basket is hard clear plastic. Does anyone know if/where I could find a rubber replacement? I think this would solve the issue but I can't find just a rubber washer for the application. Or will any washer do?
This would be the washing that connects the basket to the 1 1/2 pipe.
Old 04-28-17, 07:42 AM
Handyone's Avatar
The only place I know has rubber here is Lowe's. It's called a tailpiece washer.
It's leaking because of misalignment, a plastic washer will work without leaks.
Try relieving stress off of the vertical tailpiece by loosening all joints. Using a new washer, tighten the tailpiece to the strainer first, then make your horizontal connections over to disposer or other.
Old 04-28-17, 08:13 AM
ray2047's Avatar
I used PVC.
Do you mean schedule 40 pipe and solvent cement joints or PVC tubing with slip joints. Schedule 40 can be a lot more difficult to align so it won't leak. Any time I encounter a drain done with schedule 40 I cut it out and replace with slip joint fittings.
Old 04-29-17, 06:19 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Unlike Brian, I never use the provided plastic nut at the strainer. It just seems the threads don't mesh perfectly and will slip. I use a metal nut over the PVC tailpiece. Good solid attachment, metal to metal.
Old 04-29-17, 03:40 PM
Handyone's Avatar
You are not unlike Brian I was talking a rubber tailpiece washer.
It's true a standard plastic slip nut will not thread onto a strainer basket, the basket comes with a brass nut or you can purchase one.
