Installing a disposal
Old 05-04-17, 04:16 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi All, any tricks for installing a disposal onto the drain other than to muscling into place with one hand. Just curious.
Geo
Old 05-04-17, 04:54 AM
pugsl's Avatar
Received 76 Upvotes on 69 Posts
Nothing special, just lining up drain and don't forget to knock plug out if you have a dishwasher.
Old 05-04-17, 04:55 AM
B
Received 233 Upvotes on 206 Posts
I use a scissor jack and wood blocking as a third hand. Sure is easier than trying to hold the disposal steady to connect the installation collar.
Old 05-04-17, 05:38 AM
ray2047's Avatar
I too was going to suggest a jack but Beelzebob beat me too it. So I'll just say .
Old 05-04-17, 03:34 PM
Handyone's Avatar
It's hard to do, but I try to fit both feet in the cabinet. I face the disposer and lift it up by the ring.
Lifting by the ring is the key, especially on ones with a sound baffle.
Old 05-08-17, 05:03 PM
Geochurchi's Avatar
Update, all installed and working great,the strainer had a foam like gasket between it and the sink and minimal silicone so it basically popped right out, I used a small bottle jack with a metal plate on top and jacked it right into place,Slick!
Geo
