old cast iron tail pipe soldered into wall pipe.
Old 05-05-17, 09:57 PM
C
old iron tail pipe soldered into wall pipe.
I went to put on new bath sink trap, found the tailpipe is 1-1/4" iron, soldered into cast iron pipe in wall. The tailpipe end had become corroded and the short bottom rim broke off, leaving just the larger rim. What is a way to attach new trap without my having to heat up the soldered pipe to get it out & replace? Thanks to anyone with a suggestion that helps...
Old 05-05-17, 10:52 PM
ray2047's Avatar
Use a Fernco coupling.
Old 05-06-17, 09:31 AM
C
The problem is, the tailpipe has the downward bend at the end, with the raised ridge on the bottom. I tried a rubber trap, but the pipe is 1-1/4" and the flex trap end for the tailpipe is too large and it won't seal. I can't find one with a 1-1/4" opening. The trap part would have to go over the ridge because the short piece under it broke off from corrosion. I guess I'll have to cut the end off the tailpipe to put a connector and part of a new tailpipe on to it?
Old 05-06-17, 10:05 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Can you post a picture of what you have? We are not seeing what you see, apparently. http://www.doityourself.com/forum/el...your-post.html
