Tub spout will not come off!
Old 12-03-17, 09:02 AM
G
This spout has no set screw of any kind, I'm positive. So it must be a screw on type, but it will not budge! I have already broken the diverter pin and gate by trying to insert tools in the end to try and get some leverage in turning. Even now with those parts removed, I still can't get enough leverage to turn it. Tried rubber can opener as well. I would not put it past the previous owner to have siliconed the threads before putting on the fixture. Any ideas how I can get this thing off? Have to shower today! Thanks.
Old 12-03-17, 09:07 AM
Received 3,420 Upvotes on 3,066 Posts
A picture may be helpful... How-to-insert-pictures
Old 12-03-17, 09:31 AM
G
Hopefully this works. I've seen a few suggestions to cut it off. Tried cutting just the end to better see what was in there and here's what I see. It's on there pretty good. Definitely no set screw--can touch bare copper pipe all around when I reach through the hole on the back underside.
Old 12-03-17, 09:42 AM
G
Got it! A huge pipe wrench in just the right location while pressing down with one hand so I don't bend the pipe finally did the trick! Thanks!
Old 12-03-17, 09:52 AM
Definitely threaded on as the threads can be seen. Have you tried spraying a rust dissolver on the threads ? Something like PB blaster or Liquid Wrench.
You may need to use a bigger wrench but you also need to be prepared in case the fitting breaks or bends in the wall.
This is a similar thread..... DIY_getting-old-stuck-tub-spout-removed
Old 12-03-17, 09:54 AM
I was typing while you were toiling. Good job.
